Can we programmatically lauch the MAX
Hi
I have two questions .
Can we programmatically lauch the MAX.If Yes then how ?
Can we start &stop the CAN bus monitor programmatically.?
Please reply the both question
Thanxs
Raman
(4,258 Views)
Hello Raman,
You can programmatically run the CAN BusMonitor program and we have a KB that talks about how to do this.
Hope this answers your question, let us know if not.
Angela
(4,247 Views)
Hello Angela
Thanxs for the reply.
Can we launch MAX also programmatically ??
Raman
(4,242 Views)
Hello Raman,
The System Exec VI can be used to call any command line functions.  This is the same as typing the command into the Run window from your Start Menu.  You can call a variety of programs in this manner.  So instead of the NI-CAN directory, you can replace the string with the location of the Measurement and Automation executable.  In this case you can just replace the command line string with "C:\Program Files\National Instruments\MAX\NIMax.exe".
I hope this helps,
Angela
(4,224 Views)
