What is the TCP/UDP port for connecting to OPC Fieldpoint ?
I would like to access to An OPC Fieldpoint Server via Internet and a router/proxy/firewall.
I recorded a server listening on the ports 3010-3020 (the ports of datasocket) and I would like to do the same with OPC Fieldpoint.
Can anybody help me ?
(4,804 Views)
With Windows 2000, when you run DCOMCNFG to set up the RemoteOPC Server security, properties and permissions, you can also specify which port(s) to use for TCP/IP. Please see the attached files for screenshots.
Aaron
LabVIEW Champion, CLA, CPI
(4,804 Views)
