Where can I find the nixnet.h and .lib at the NI-XNET Drivers?
Hy,
I'm using:
Hardware: NI-XNET| Driver: NI-XNET 1.5| OS: Windows| Programming language: C++ (QT environment)
I suppose that I'm missing somethingSmiley Wink, but I want to include the nixnet.h and .lib at my project and can't find them...
Thanks for advance,
Aviad
(9,634 Views)
Obviously that I missed something ...
Everything worked out!
All the best
(9,627 Views)
Hey.. i have a quick question for you.
Did you use QT Creator with VS2010 compiler? or with MINGW, OPENGL?
If you used MINGW, did the nixnet.h and nixnet.lib work with the compiler?
Cheers,
Adeel
(9,149 Views)
I use Qt 4.8.1 with MinGw.
It's work fine (debug mode, I don't try the release mode).
If it's can be useful, I add those lines for the pro. file:
NIPATH = "C:/Program Files (x86)/National Instruments/NI-XNET"
NICOMP = "C:/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/lib32/msvc"
INCLUDEPATH += $$NIPATH
INCLUDEPATH += $$NICOMP
LIBS += -L"C:/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/lib32/msvc" -lnixnet \
Hope I was helping here,
Aviad
(9,132 Views)
thanks, it works perfectly!!!
(9,021 Views)
