Thanks for the reply John.  Jassem is also working on this issue.  The failure occurs when we use driver version 2.2.  We tested driver versions 2.1.1, 2.1.2, 2.1.3.
Version 2.1.1 worked for single packet messages, but not with multi-packet.
Version 2.1.2 and 2.1.3 work for everything.
Version 2.2 does not work at all.
If necessary, I can reinstall 2.2 and run NI Spy, but right now our fixture is up and running with version 2.1.3 and we need to make up for the backlog that accumlated during the downtime...so it may be a while before I'm able to get the spy data.
Thanks.
