I would recommend against writing DIRECTLY to Excel, while the CAN vi is running, the MSOffice interface is too slow to be doing while the CAN vi is running.  There are 2 different ways you can get around this problem though.
1. When you receive a CAN frame you want to log, write it to a buffer of some kind in Labview (this could be a string buffer wired to a shift register, it simply adds the new data to the end of the buffer) then when your VI closes, it writes the string data to an excel worksheet.
2. You could log the data to a text file, if you use the Write File.vi (in the File I/O pallette) you can quickly write data to a file if it is done correctly.  DO NOT use the VI's on the first row (Write to Spreadsheet.vi and Write Characters to File.vi) because they will be too slow, they open the file, write data, and then close the file each time they run, which takes too much time.
As for changing the buffers, you can do that, if you change the buffers at the time you call ncCANConfig, if you change the buffers after that you will get an error.
