XNET Signal In Waveform no data
Hi! I use PCI-8513, Labview 2018SP1, XNET 16.0 I have a strange problem, When my software runs for a long time, XNET Read.vi(Signal Waveform) no waveform data output, but XNET Read.vi(Frame CAN) could reveived can message normal, The error cluster also has no error output I rebooted the software and everything was fine again,The same problem would occur hours later Looking forward to your help, thank you
(2,914 Views)
Accepted by 小_羊
Not sure whether your problem is similar to this post (frames dropping over a period of time) https://forums.ni.com/t5/Automotive-and-Embedded-Networks/XNet-signals-Lost/m-p/3314746
(2,898 Views)
