XNET support CAN and CAN-FD in the same interface
@WaldemarM wrote:
I'm sorry, but I have overlooked first that you try to use the non-ISO-mode. This is was the preliminary CAN-FD standard which has been replaced by the ISO CAN-FD. The abily to mix CAN 2.0 and CAN-FD is a new feature of ISO mode and is not supported by non-ISO.
Are you sure, you need the non-ISO mode? Most CAN-FD hardware nowadays use ISO.
yes sir but do you have anything else in mind.
Message 11 of 11
(683 Views)
