can we simulate CAN card in MAX
Hi
We can simulate DAQ cards in MAX.But can we simulate CAN card in MAX ?????
I am using PCI CAN series-2 card.
Please reply
Message 1 of 9
(7,615 Views)
The newer versions of NI-CAN have virtual CAN ports, ports CAN256 and CAN257.  If you install NI-CAN, try configuring those as fake CAN ports in MAX.
Message 2 of 9
(7,613 Views)
Hi
Thanxs for reply
In my PC NI CAN 2.3.2 is installed.Which is the Newer version of CAN.
Please explain more
Regards
Raman
Message 3 of 9
(7,608 Views)
Hi
I am using NI CAN 2.3.2 version & If i am correct we can simulate CAN for the CAN version 2.3 or more.
But having CAN 2.3.2 i am not able to simulate the CAN card.
Please reply as soon as possible.
Regards
Raman
Message 4 of 9
(7,602 Views)
Hi
The 2.3.2 allows you to simulate 2 CAN Ports (CAN256 and CAN257) directly in your code. But you can not, as you know from DAQ, simulate CAN devices within MAX.
DirkW
Message 5 of 9
(7,592 Views)
Does CAN version 2.7.5 allow the simulation of CAN card.Kindly clarify regarding the same.
Message 6 of 9
(5,627 Views)
Did you read the post, CAN256 and CAN257 can be used as types of simulation.  It routes CAN data to virtual ports and you can write your code to do what ever you want with that data.
Message 7 of 9
(5,622 Views)
yes,I am clarified.Is it possible to post a sample code related to the same?
Message 8 of 9
(5,617 Views)
No posting of code is needed, open the Help >> Example Finder.
Search for the example CAN Receive.vi, and Transmit Receive same Port.vi.  Before running the CAN Receive.vi set the interface to CAN257, then run it.  Then in the Transmit Receive same Port.vi set the interface to CAN256 and then run it.  Now when you click Write it will send a frame out on CAN256.  CAN256 and CAN257 are virtual loop back ports.  What is sent on one is received on the other.  So you should see the frame you wrote appear in the CAN Receive.vi which is monitoring 257.
Using this technique you can write code that monitors one of these ports, then reacts sending simulated data when requested, or set it up to just periodically send the data you want.
Message 9 of 9
(5,608 Views)
