01-05-2015 07:52 AM
Hello
Let assume I have 22 Nodes, and how can I get some TPDO from each, per one request, is it possible? Can you explain me common approaches?
Thanks.
01-06-2015 11:09 AM
I would start with the TPDO Read example found in Help->Find Examples->Hardware Input and Output->NI Industrical Communications->CANOpen
That sets up a single TPDO Read. From there, you should be able to modify the code to iterate through an array of Node IDs rather than just listen for the single TPDO.
