CAN PDO mapping
Hello
Let assume I have 22 Nodes, and how can I get some TPDO from each, per one request, is it possible? Can you explain me common approaches?
Thanks.
(5,088 Views)
I would start with the TPDO Read example found in Help->Find Examples->Hardware Input and Output->NI Industrical Communications->CANOpen
That sets up a single TPDO Read.  From there, you should be able to modify the code to iterate through an array of Node IDs rather than just listen for the single TPDO.
(5,061 Views)
