comm loss simulation
How would you simulate a comm loss?
I thought by simply using the conditional statement and taking out the write to CAN block, I would not transmit to CAN, but monitoring the bus shows that nothing happens to the frames and they keep transmitting regardless. I can see the change implemented if I stop the VI and then restart the VI, but I would like this to happen  dynamically. I thought about using the stop and erase block or even the flush block, but then realize that the timed loop would not have anything for a session to write to CAN after you enable the conditional statement and the write.VI.
Attached is a subset of the larger VI I am using. All it is is a timed loop in which I am writing to CAN a user controlled CAN message from the UI (front panel), using a queued output mode write.VI after creating a session outside of the loop to write the specific CAN card and frame.
How would I be able to disrupt comms of a particular frame being sent out and then recover it for the purposes of fault injection? I was hoping that some user controlled boolean button could enable the comm loss from the front panel and restore it by disabling the button. Any ideas?
(6,097 Views)
If you are using XNET, you probably have a cyclic frame, which will transmit old data. However, there is a property Session>>Frame>>Skip N Cyclic Frames that you can use to skip sending N frames to simulate a disconnect of a particular frame.
(6,095 Views)
