transmit periodic multiple frames in CAN Network using NI-XNET
If I have a CAN BUSS, and want to transmit different frames that correspond to different sensors, how is a network created with NI-XNET. The examples show a way to do it with NI-CAN, but it is not what I am looking for.
Say I have two sensors on a CAN BUSS, how would I have them transmit on the same port in a specified periodic manner using the API, what the user inputs in the front end VI?
If I am working at the frame level, how can I get the signal list for the frame? It comes back empty and throws an error.
(7,714 Views)
What does it mean to have the maximum number of sessions exceeded when using the Conversion block?
(7,712 Views)
Interesting....
I cannot get the example figure 15 in http://www.ni.com/white-paper/9717/en to work out.
I get the error message:
Error -1074384883 occurred at XNET Create Session (Frame Output Single-point).vi:1
Possible reason(s):
NI-XNET: (Hex 0xBFF6300D) You tried to open the same frame twice. This is not permitted. Solution: open each frame only once.
Any ideas?
(7,702 Views)
Hello estradjm,
If I understand what you are doing you have 2 sensors that are sending data onto a port then you are sending that to the bus. You can send the 2 sensors on the same port but it would come in as a single frame, which it seems you are seeing. You would use the API to parse that frame to split between the 2 sensors data. Or you could send 2 frames and have each correspond to a single sensor.
As far as the error when you run the Fig 15 example, can you verify that error is thrown when you have Measurement & Automation Explorer and your other LabVIEW programs closed?
Hope this helps.
BeauH
(7,695 Views)
