error when opening programm again
I open the file, start the programm.It opens DeviceNet. It's working properly.
Then I stop the programm and close the file.
Then I open the file again and start the programm again. After one second, the errormessage, which is shown in the picture appears.
How can I solve the problem? I can only use the progamm, when I restart the computer.
(4,087 Views)
In "DeviceNet Interface Configuration" of "Easy IO Config.vi", change "Automatic" to "Scanned".
(4,025 Views)
Also be sure to stop the VI using the stop button on the front panel and not the abort button, otherwise the Easy I/O Close and DAQmx Clear Tast operations will not complete.
Best Regards,
JLS
Best,
JLS
Sixclear
(4,017 Views)
