CAN drivers CVI 5.0.1
I work with LabVIEW, but i have some applications madded in LabWindows/CVI v5.0.1 and i use the NI-CAN 2.2 and this driver don't work with CVI, there are any driver to work with CVI v5 and LabView 7.1 together?
I have the NI-CAN 1.4.2 for work to CVI but don't work with LV7.1.
If was possible use the driver NI-CAN 2.2 in CVI will be great.
(3,468 Views)
Hello PALMEI,
as you probably found out that there is no NI-CAN driver that does support both, CVI 5.x and LabVIEW 7.1. Here is an overview of the different NI-CAN driver versions and the supported ADEs:
KnowledgeBase article # 2V27R4HR
However, I took the CVI 6.0 compatible nican.h file and the .lib files from the NI-CAN 2.2 driver and attached them. Depending on your compatibility mode ('Microsoft Visual C' or 'Borland') you need to copy the appropriate libraries to your local CVI directory. I'm not 100% sure, if the CVI 6.0 files work with the 5.0.1 version, but I think it should work.
-B2k
(3,432 Views)
