if no CAN hardware is present on the system then why we get nican.dll error
Hello I have no CAN Hardware present or using it. But when i try to open MAX....a pop-up shows that 'module could not be found'...which i was not gettings earlier.
Pls check the attachment for the error....
Kirit
(6,226 Views)
Hello Kirit,
MAX still has to use NI-CAN to scan your system to see if any NI-CAN hardware is present.
I would suggest un-installing NI-CAN (if you really do not need it) or repairing the install.  Let me know if that works.
O. Proulx
www.ni.com/support
(6,168 Views)
