 Kirit
			Kirit
			01-21-2010 12:26 AM
Hello I have no CAN Hardware present or using it. But when i try to open MAX....a pop-up shows that 'module could not be found'...which i was not gettings earlier.
Pls check the attachment for the error....
Kirit
02-02-2010 03:02 PM
Hello Kirit,
MAX still has to use NI-CAN to scan your system to see if any NI-CAN hardware is present.
I would suggest un-installing NI-CAN (if you really do not need it) or repairing the install. Let me know if that works.
