Home
Community
Discussion Forums
Additional NI Product Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
initial ip-adress of fp-1600
Yves
Active Participant
05-25-2004
07:54 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
what is the initial ip-adress of a FP-1601
0
Kudos
Message
1
of 2
(3,598 Views)
Reply
Re: initial ip-adress of fp-1600
AlessioD
Active Participant
05-28-2004
04:27 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yves,
the initial IP Address should be 0.0.0.0. This is the IP that gets set whenever you manually reset the IP address of the module using the appropriate DIP Switch.
AlessioD
1
Kudo
Message
2
of 2
(3,598 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
