initial ip-adress of fp-1600
what is the initial ip-adress of a FP-1601
(3,585 Views)
Yves,
the initial IP Address should be 0.0.0.0. This is the IP that gets set whenever you manually reset the IP address of the module using the appropriate DIP Switch.
AlessioD
(3,585 Views)
