is a Vector make CAN CardXL compatible with LabVIEW7.1 or LabWindows CVI
(4,257 Views)
As long as you have someway to communicate to the hardwares driver, you're OK. This is usually a .dll of some type.
All the Vector cards that I have worked with have a .dll that you can interface to from either LabVIEW or LabWindows. Vector actually supplies many LabVIEW dirvers for their products, so I'd check on their website in the support area. That will save you a lot of work.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(4,253 Views)
Vector announced a new LabVIEW driver for the CAN Card XL this month. So calling the VECTOR Support could be a good idea.
(4,234 Views)
