08-06-2004 07:16 AM
08-09-2004 07:26 AM
08-09-2004 08:08 AM
08-09-2004 05:34 PM
01-13-2005 05:22 PM
01-13-2005
06:13 PM
- last edited on
05-15-2025
03:54 PM
by
Content Cleaner
Hi svp,
your NicanErr.tx log file indicates that you use NI-CAN version 2.1.1. Do you still get that error when you upgrade to the current version 2.2?
You can find it here:
http://digital.ni.com/softlib.nsf/websearch/C98C33F3DB0459BE86256EBD004B6ED0?opendocument&node=13206...
-B2k
01-13-2005 10:19 PM
02-14-2008 10:59 AM
02-15-2008 08:19 AM
This is not the way you should work on this forum. You posted the same problem to four different threads. Don't do that. Instead you should open your own thread and deliver as much information as possible.
The 0xBFF62002 error is internal and there is not that much you can do. Whenever this error occures a nicanerr.txt file is generated to the following location:
\\Program Files\National Instruments\NI-CAN\bin
Attache this file to your own thread and if possible add ashort example showing this error, so we can reproduce it here.
If you work that way, i am pretty sure we can help.
DirkW
03-03-2022 03:59 PM
