pci can xs2 high voltage wake up
Is this device capable of high voltage wake up for single wire can? If not, how can the NSTB line on the can chip be set low to enter this mode for waking up a remote device.
(3,568 Views)
Hi chrisjohnson,
yes, when you have the card configured to use the single-wire physical layer, you can set the 'Transceiver Mode' to 'Single Wire Wakeup' to drive a higher voltage to the bus to wake up other sleeping nodes.
If you use the single-wire physical layer, and the transceiver on teh PCI-CAN card is set to sleep ('Transceiver Mode' set to 'Sleep'), the transceiver will wake up as soon as a high-voltage is detected on the CAN line.
-B2k
(3,562 Views)
