setting up communication with an ECU through a vector can case
I am trying to communicate with an ECU through a vector can case..does anyone have information on how i can set up the communications with the vector can case?...is there a VI function library for this?
(7,356 Views)
Check this link..
LabVIEW vxlapi CANCASEXL configuration
http://forums.ni.com/t5/LabVIEW/LabVIEW-vxlapi-CANCASEXL-configuration/m-p/2956269#M852546
Munna
(7,354 Views)
Accepted by topic author alpony01
Here is the library written to talk to Vector CANcase hardware.
https://decibel.ni.com/content/docs/DOC-30180
It can only do basic frame read and write and XNet hardware gives much more control over the hardware, but I understand if you have to work with what you have.
(7,349 Views)
thank you
(7,319 Views)
