02-08-2007 08:43 AM
		02-09-2007
		08:24 AM
 - last edited on
		05-15-2025
		04:18 PM
 by
			Content Cleaner
Hi
Make sure you have installed ni-rio 2.1 Here is the Link . Or ni-985x 1.2.1. NI-CAN supports only cRIO 900x controllers running Pharlap RT. There is no support for cRIO 90xx Controllers running Vx Works. The use of NI-CAN api functions makes only sense if you try to use the virtual interface for frame to channel conversion. Otherwise you have to use the FPGA elemental I/O to access the 985x c-series modules. The cRIO drivers mentioned above install examples for these cases. The LabVIEW help describes the "How to".
DirkW
05-25-2007 10:48 AM
05-29-2007 04:34 AM
Hello Yougo,
Unfortunately you need to develop you own API on your controllers based on VX Works.
05-29-2007 08:57 AM
Right now there is no NI-CAN support for VxWorks available, but we are looking into this right now, because of the increasing number of Requests, like yours. But i can not tell any timeline or release date yet. Hopefully this works out until the end of the year.
DirkW
09-09-2011 03:23 PM
Well.... it is now September, 2011.
Are the NI CAN drivers available for VxWorks?
09-09-2011 03:49 PM
Howdy,
Still no support for NI-CAN in VxWorks, but there is NI-XNET support for the NI-9862. If you are using the NI-9853 it might be possible to use the NI-XNET Frame to Channel Conversion library to bring data from the FPGA and use NI-XNET VI/databases to work with the Frame and Signal information.
09-12-2011 05:11 AM
Hi triviper,
Indeed, the NI-CAN driver/hardware is slowly being replaced by NI-XNET because this latter is better suited for other protocols such as LIN or FlexRay. Which explains why there won't be a driver directly used by cRIO under VxWorks. As stated several times, there are libraries to use to import CAN data from the FPGA to the RT part.
Rik.
Eric M. -  Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer -  Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
