what is the minimum baud rate that PXI 8461 CAN support
what is the minimum baud rate that pxi 8461 CAN support
(3,874 Views)
The PXI-8461 is the high speed CAN. The minimum baud rate is 5kBits/s. Refer to the following Knowledge base article:
CAN Physical Layer Standards: High-Speed vs. Low-Speed/Fault-Tolerant CAN
Hope this helps.
DiegoF.
National Instruments.
(3,874 Views)
