wrong IO data buffer when using COS or cyclic
Hello All,
I am using CVI 7.0 for DeviceNet communication with or device...
I have a problem with ReadIO with COS or Cyclic...
It works perfectly when I open a polled IO connection, the data buffer retrieved correspond to my selected assembly...
If I open a COS or Cyclic IO, the Data buffer is giving me random number... If I explicitly read the proper Epath through the Assembly Object, the buffer looks fine...
This is the code that I use to get the proper data
    NCTYPE_UINT8 locServiceCode = 0;
    NCTYPE_UINT8 locServiceData[ 80 ];
    NCTYPE_UINT8 * locpServiceDataPointer = locServiceData;
    NCTYPE_UINT16 locActualServiceDataLength = 0;
    NCTYPE_UINT16 locProduceInstance = 0;
// Read the
    if (glConnType == eCOS)
     GetAttributeSingle(GetGlobalDeviceHandle(), eCONNNECTION_ID, 1, 102, &locProduceInstance);
    else
     GetAttributeSingle(GetGlobalDeviceHandle(), eCONNNECTION_ID, 1, 104, &locProduceInstance);
    locActualServiceDataLength = 1;
    locServiceData[0] = 0x03;
    locErrorCode = DoService(GetGlobalDeviceHandle(), 0x0E, eASSY_ID, locProduceInstance, &locActualServiceDataLength, locServiceData, sizeof( locServiceData ), locServiceData );
    memcpy(*locpReadIoDataBuff, locServiceData, locActualServiceDataLength);
(4,096 Views)
Sorry for the 2 previous posting, Somehow I must have press tab and press submit post every time I tapped enter...
Any how... Is any body else has encounter the same problem?
(4,091 Views)
You know what... my mistake.... The device I have, for some reason, does not work... sorry for all the troubles... (strange though that It works with explicit messages)
(4,084 Views)
