Problems with ncWriteMult in C/C++
i try to use the ncWriteMult function in my C-application to write a block of CAN Messages but it doesn't work like i expect it to work. So is there any example how to handle this function in C/C++.
Andreas
(3,453 Views)
Hi!
I found not exactly an example for ncWriteMult but for ncReadMult. I hope it helps nevertheless.
If you install NI-CAN (Version 2.3) in the installation menu you can select 'Support for Borland C'. After the installation you can find the example 'Readmult.c' on following path:
C:\Programme\National Instruments\NI-CAN\Borland C\Frame API examples\Readmult\
Wolfgang
(3,421 Views)
