xnet FrameInQueued memory session
I'm trying to convert an existing program that used NI-Can to Xnet.  I don't really want to use the FIBEX file for CAN so I'm trying to create a memory session.  I need to be able to specify the incomming message ID.  In NI-Can I used the filters.  It looks like if I could use the mode FrameInQueued then it would work.  I get an error when trying to use that mode.  Creating a session with FrameInStream works but it doesn't filter out by ID.  Is there a way to create a session input that will filter by ID?
(6,304 Views)
Hi MickF,
What error are you seeing when using FrameInQueued.  Also, have you checked out the following document on migrating from CAN to Xnet: http://zone.ni.com/devzone/cda/tut/p/id/9717
Hassan Atassi
Senior Group Manager, Digital Support
(6,286 Views)
