Biomedical User Group Discussions
AR/FFT Plot Legend Problem
did anyone had a problem with Plot Legend of AR and FFT Spectrum of ECG? I want to add this section, but when I had added it, LabVIEW did not save it. I tried a coupleof times, but every time was the same.
I did the same thing for a FFT Spectrum of EEG and it worked. I don't understand the problem with ECG.
Is there some properties I nedd to check for showing Plot Legend?
(4,508 Views)
Sorry for the inconvenience. I think it is the same issue in https://decibel.ni.com/content/message/78123. This is an expected issue in the current version. Please use waveform graph directly if you would like to save the plot properties.
Thanks!
ZJ
(3,615 Views)
