Biomedical User Group Discussions
Can I use the Noninvasive Blood Pressure Analysis VI with a NI 9237?
Hello!
I would like to know if there is any way to use the NIBP Analysis VI with a NI 9237.  I've tried using a DAQ Assistant to get the data (because the Biomedical DAQ Express VI does not support voltage tasks), but even after converting the data to an array it does not seem to give me any usable results.
Is this possible?  If so, how?  I don't have much experience with the NIBP data so it may just the the data is in the wrong format.
Here is a simplified version of how I was trying it.  It's giving random blips of data and 0 at all other times.
Note: This is an Applications Engineer asking on behalf of a customer
Thanks!
Patrick W.
Patrick W.
(5,388 Views)
Accepted by topic author Patrick_NI
NIBP Analysis VI is a one-shot analysis VI. So you cannot call it in a loop. You should first get a complete cycle of NIBP signal and then input the signal to the VI.
And, when you are using the array instance, you should connect the sampling rate input.
(3,992 Views)
Thank you
Patrick W
Patrick W.
(3,992 Views)
