Biomedical User Group Discussions
ECG Features extraction
I'm trying to extract the ECG features (P, QRS, T, ST elevation, etc.) inside a text/csv file.
I use the existing ECG feature example and I tried to modified, to save the result in txt file with my beginner level in LabView, but the result of Biomedical toolkit and my results look quite different. I'm wondering why they are different ?
In fact, when comparing the result of ECG BMTK and the attached file, the results are not the same. I don't understand why !
I just want to save the extracted ECG features inside a text/csv file (P onset, P offset, QRS onset, R, QRS offset, T onset, T offset, ST level). Can you give any indication how to save these features ?
is there a method to save ECG features annotation in CSV or txt file from the BMTK ? how to add ST elevation to this annotation file generated by BMTK ?
Is there is any method to save the annotation file (containg the ECG features as P, R, S, etc.) from the BMTK in CSV or in text file ? is there is a way to add ST elevation into the annotation file ?
Walid
Message 1 of 1
(3,515 Views)
