Biomedical User Group Discussions
EMG simulator
Hi Gu,
I can post the sEMG simulator for isometric sustained contractions, with changing RMS and MDF over time. It also could be added to the Biomedical Startup kit.
Let me know what you think.
Ferreira
Arthur de Sá Ferreira, PhD, PT
http://www.phd2.com.br
Message 11 of 24
(7,098 Views)
Hi Amit,
I hope this VI suits your project.
Ferreira
Message 12 of 24
(7,098 Views)
Hi Ferraria,
Very pleased to see the VI. Thank you for sharing the codes.
ZJ Gu
Message 13 of 24
(7,098 Views)
what is the mathematical equation for the simulator.
Message 14 of 24
(7,098 Views)
Hi Mr. Gu, where can we download the Biomedical Kit Source Code version? It seems not publicly available. Only the binary version is free for download.
Cheers, Forrest
Forrest Sheng Bao, Ph.D.
Assistant Professor, Dept. of Electrical & Computer Engineering
University of Akron, Akron, OH, USA
https://sites.google.com/site/forrestbao/
Message 15 of 24
(7,098 Views)
You could contact nish.dsp@ni.com
Thanks!
ZJ Gu
Message 16 of 24
(7,098 Views)
Hi Ferreira,
You have posted a model for sEMG simulation and provided an equation in this topic. And you said that it was provided by Shwedyk, Balasubramanian & Scott (1977) IEEE Trans Biom Eng 24: 417-424.
But I cannot find the equation you provided in this paper.
Could you tell me where can I find the equation?
Thanks!
Message 17 of 24
(7,098 Views)
Hi liuxs0,
It is an interesting question. The book "Electromyography: Physiology, Engineering, and Non-Invasive Applications" (by Roberto Merletti and Philip Parker) refers to this equation as being from the work of Shwedyk et al. 1977. I also could not identify the same equation in the original work, so probably it was derived from the Shwedyk's original study. Anyway, the equation reported in Merletti's book is again in attachment.
Arthur
Message 18 of 24
(7,098 Views)
Hi Ferreira,
Thank you for your reply.
I will try it.
Message 19 of 24
(7,098 Views)
Hi, Ferreira
I have tried to generate isometric sEMG signals by building different MUAP trains added withwhite  gaussian noise artificially. But it didn't work. I want the simulated sEMG to test and verify my decomposition algorithm, I have tried to change the code of your model to generate isometric sEMG and failed. what can I do ?
Evoly Wan
Message 20 of 24
(7,098 Views)
