Biomedical User Group Discussions
cut ECG sample data
hi guys,
i need some help.
how can i cut ECG sample data into portion (in time duration) so that i can just test the portion i'm interested of.
fyi, i already download few sample ECG data from MIT-BIH but the data is too long, about 30 minutes.
the sample data consist of normal heartbeat as well abnormal heartbeat
i just want to test the abnormal one with the algorithm.
many thanks for your response.
(4,418 Views)
Hi Nur,
You may use Extract portion pallette in the express panel to extract a particular portion of the signal.
KP
(3,274 Views)
Hi nurlaila,
You can also use Array Subset to extract a subset of your data array. Here is a community example that shows how to do this:
https://decibel.ni.com/content/docs/DOC-22642
This example uses cursors on the graph to select the portion of data you want to extract.
Daniel Hays
Applications Engineer
Daniel Hays | Test Software Business Manager
(3,274 Views)
