BreakPoint
30k posts by crossrulz
Today I noticed that crossrulz has written more that 30k posts in this forums and got a new badge 30k_shield_edit.
Congratulations to this achievement.
The fact that one in six messages is marked as a solution speaks for the outstanding quality of the messages.
(638 Views)
(600 Views)
Congratulations @crossrulz! 🏅
(587 Views)
Tim knows everything, but especially anything to do with serial ports. Last time I used serial ports was in the late nineties with LabVIEW 4.0 where I had to talk to two different instruments, one that used \n as termination character and one that used \r instead. Tim wasn't around then, but definitely would have steepened my learning curve. 😄
He is the "version conversion" master and must have a basement full of systems with any LabVIEW version from 1.0 to infinity.
Thanks for all your contributions. I definitely learned a lot from you.
(577 Views)
(525 Views)
I doubt I would have been able to help then as I barely even knew that a serial port was even a thing.😋
Sadly, no. Surprisingly, I only need 4 versions to do nearly all conversions
(518 Views)
Congratulations and thanks for all your contributions!
(483 Views)
