BreakPoint
Carnac the Magnificient - sarcastic answers to serious questions/comments
Access is denied for me. I can only assume that the LMGTFY link went worse than usual.
Message 51 of 338
(13,187 Views)
https://forums.ni.com/t5/LabVIEW/XPlane-9-interface-with-LabVIEW/td-p/3293698
It actually was not that bad.  But I was about to make it worse and then decided not to.  I have gotten better playing with others for the most part. Smiley Wink
Message 52 of 338
(13,184 Views)
@LiliMcDonald wrote:
@Hooovahh wrote: Also do people just think this is twitter or something?  I guess you can post questions from Facebook now somehow, not sure how well that integrates or if @ and # work as intended but I'm guessing they don't.
@in other Lithium hosted communities, it is possible to @ mention a username so that the person is notified. It's handy for replying to users in a long thread. We don't have that enabled here though.
Over at Scubaboard.com that is an option.  Another really nice feature they have is that when you click on a thread you have been following it will automatically take you to where you stopped reading.  Basically going to the first unread response.  On the NI boards I look at how many new replies there are and try to figure out how many pages to go back and try to figure out where I left off.
Message 53 of 338
(13,180 Views)
Somebody needs to go through their NI Forum settings...
Message 54 of 338
(13,173 Views)
If you click on the number that tells how many unread replies there are in the thread, it will take you to the first new thread.
Message 55 of 338
(13,141 Views)
I guess they make it more dummy proof on the other site and go directly to the first unread.  And put a big button by the page numbers.
Thanks for the info.
Message 56 of 338
(13,121 Views)
Doens't work on the mobile site version.
Message 57 of 338
(13,117 Views)
So not the NI forums but I found this linked on Reddit and there are some great answers to a user asking others to do their homework.
https://www.quora.com/Homework-Question-How-do-I-write-a-program-that-produces-the-following-output-...
Message 58 of 338
(12,947 Views)
@IronLayerSecurity wrote:
We're working on a cybersecurity startup in the data obfuscation space and are in need of a senior LabVIEW developer located in the United States.
Jeff
Does it help if the LabVIEW code is obfuscated, too?  I know a few senior engineers that code that way! 😄
Jim
Message 59 of 338
(12,783 Views)
Re: about horizontal and vertical scroll bar
[ New ]
Asif138 wrote:  how can i move scroll bar at any angle ?
Rotate your monitor screen to the desired angle and then just scroll away.
http://forums.ni.com/t5/LabVIEW/about-horizontal-and-vertical-scroll-bar/m-p/3595305#M1007330
Message 60 of 338
(12,301 Views)
