BreakPoint
Carnac the Magnificient - sarcastic answers to serious questions/comments
Message 221 of 338
(6,147 Views)
Trouble with DIO !
Did you know that a digital line cannot output a sine wave?  I am in just complete shock that a switch cannot just output whatever value I want!
Message 222 of 338
(6,052 Views)
@crossrulz wrote:
Trouble with DIO !
Of course with 8 DOs (and a few resistors) you can make 1 8-bit AO...
I can hear his manager say: I still thing we need to find a software solution....
Message 223 of 338
(6,045 Views)
@crossrulz wrote:
Trouble with DIO !
BTW. this reminds me of my old 8088 PC. It had a speaker that only beeped at one frequency. Some clever people came up with the idea to PWM the beep, resulting in speech output from the speaker.
This is actually getting way to close to a serious answer... Maybe I should post it in the original thread?
Message 224 of 338
(6,043 Views)
wiebe@CARYA wrote:
@crossrulz wrote:
Trouble with DIO !
Yes dangerously close to being a useful idea.
Pulse Density Modulation  (used by digital microphones in cell phones) only needs a low-pass filter.
Ben
Message 225 of 338
(6,037 Views)
And we even have code I wrote over 10 years ago. 😄
Message 226 of 338
(6,054 Views)
Deta Sigma Simulation? Is that Delta Sigma Simulation? Is that the same as Pulse Density Modulation?
I'll probably need to read some wiki's on that. I never can remember the term Pulse Density Modulation when I need it.
Message 227 of 338
(6,012 Views)
It is one way to create a PDM bit stream, but I am sure there are others. Straight from Ben's link above:
Message 228 of 338
(5,993 Views)
PDM...
As an "old scope jockey" I see the decoding as exactly what I would expect if I had a bit stream driving an RC circuit where the RC timeconstant acted as low pass filter. IT could also be handled with moving average where the window size was large enough.
Ben
Message 229 of 338
(5,935 Views)
Here's a 'perfect' reply for someone asking what the perfect solution would be:
As seen (not sarcastically though) in the wild in this thread: By Yamaeda, in this thread (so kudo that one if you like).
Message 230 of 338
(5,775 Views)
