BreakPoint
Carnac the Magnificient - sarcastic answers to serious questions/comments
@AeroSoul wrote:
There are also e-books, those can also be obtained by alternate means 😄
Really? I had no idea 😉.
Message 271 of 338
(4,313 Views)
I'd leave, too, if I had to use the Actor Framework but I'd rewrite the subject line to "LabVIEW developer disappears after lunch".
https://forums.ni.com/t5/LabVIEW/Actor-Framework-LabVIEW-disappears-after-launch/m-p/4183801#M120982...
Jim
Message 272 of 338
(3,800 Views)
Just keep adjusting the system clock, so lunchtime never comes.
Message 273 of 338
(3,793 Views)
I want to download LINX but I can't download it - NI Community
also i want heartrate
I always wanted a heart rate too...
Although if you don't have one, it can't stop... 🤔
Message 274 of 338
(3,685 Views)
You always have a heart rate!  It might be ZERO but that is still a rate.
Message 275 of 338
(3,657 Views)
Even if you don't have a heart? 🤔
Message 276 of 338
(3,668 Views)
In a worst case scenario, that's permanent.
There is no such thing as an instantaneous heart rate, just a "elapsed time since last beat". 😄
(Reminds me of the idiot testing the turn signal: "works...doesn't work...works...doesn't work...")
Message 277 of 338
(3,666 Views)
Yes!  Hopefully, under that condition, your blood is being externally perfused and a viable donor organ is close by.
Message 278 of 338
(3,662 Views)
That is what makes it very hard to determine a frequency from a digital signal. Especially if the frequency can be low and high. You can't use the same strategy to calculate the frequency, at least not accurately and responsively.
What is even harder is to explain this to a customer.
Message 279 of 338
(3,640 Views)
Hey!  I resemble that!
https://forums.ni.com/t5/LabVIEW/Labview-Ubidots/m-p/4195950#M1214397
Jim
Message 280 of 338
(3,565 Views)
