BreakPoint
Coffee Break Coding Challenge
Spoiler
Not even coding it! .... Integer to "String",  String to byte array, For each element in array build new array with the remaining elements sorted(split array, sort array), New array to string, Sort String Array, Threshold New array as String. Threshold index rounded up {to get the next higher} Scan String %d.
Spoiler
Isn't ASCII fun?
Message 11 of 26
(7,344 Views)
Another attempt (shaped by an irrational aversion to strings).
Ian
Spoiler
Message 12 of 26
(7,325 Views)
I enjoy a good challenge, but I think I over-thought this one...
Spoiler
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 13 of 26
(7,269 Views)
Unlike my previous solution, which is brute force, this one intelligently considers the numerals of the provided number. It is much quicker, however I expect that it has already been created in one of the spoilers by someone else because it is far from profound.
Spoiler
Excuse the icon
Spoiler
Message 14 of 26
(7,250 Views)
Another excuse for the good, old and I mean 700 years old, method of Narayana Pandit.
Spoiler
Message 15 of 26
(7,211 Views)
Spoiler
Inplace operations used in the 14th Century?
I realize memory used to be a scarce resource but then again... "There is nothing new under the sun." Eclesiastes
Ben
Message 16 of 26
(7,186 Views)
I was trying to run this in LabVIEW 1345 with highlighting on, but the illuminated diagram on the parchment didn't change
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 17 of 26
(7,166 Views)
Did you try it with a 1.2 Candle power candle?
Some of those examples could only be realized uisng an upgraded candle.
Ben
Message 18 of 26
(7,161 Views)
I had forgotten to renew my SSP, so I didn't get the upgrade that year.
Putnam
LabVIEW Champion
Message 19 of 26
(7,148 Views)
Brute force:
Jim
Message 20 of 26
(7,134 Views)
