BreakPoint
End of Windows XP support
Speaking of obsolescence ... The day has finally arrived. I have a line of equipment that runs XP with LV 8.5. Still maintain it and even create a "new" system once in a while. Other than the obvious security concerns (these machines are standalones, they do not get hooked up to the network) I'm really not that concerned. Should I be? XP is too solid to abandon.
PaulG.
Retired
Message 1 of 36
(16,881 Views)
The only issues I can immediately think of are trying to replace hardware as it wears out. At some point you will have hardware for which there aren't WinXP drivers. Until that time, a system that isn't connected to the world shouldn't be at risk regardless of no new security patches, which I'm hazarding a guess, were about 99% of the patches beyond the major service patches. Most of the other issues that WinXP started with have pretty well shaken out since 2001!
On the other hand, my employer is doing a massive switchover to Win7 this month, I am not looking forward to backing up all the data and having to reinstall multiple versions of LabVIEW and other non-standard corporate disk image stuff. Bleh. Then again Word 2003 is 11 years old (seems to do what I need but ...)
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 36
(16,872 Views)
Windows 7 Embedded is on my to-do list of things to trial
This afternoon I also found that NI are supporting it, to some extent at least
_____________________________
- Cheers, Ed
Message 3 of 36
(16,866 Views)
Are you saying that I should do something about  my windows 95 and windows NT4 computers? 😄
Message 4 of 36
(16,865 Views)
Legacy systems are the bane of my life. When Miscosoft stops support for an OS, our IT department stops support as well.
Which means I have to pick up the support.
Our mechanical workshop has an expensive milling machine running Win 98SE. Guess who has to keep it running O_o
- Cheers, Ed
Message 5 of 36
(16,858 Views)
Fortunately, I managed to get away from supported the test racks I developed on Windows XP.  As had already been said, the only real concern I had was finding replacement hardware.  Even then, I think they could be updated to Windows 7 without any issues.
But now that everybody is finally updating to Windows 7, the big question is how long will Win7 be supported.  Windows 9 is coming.
Message 6 of 36
(16,857 Views)
I've managed to migrate everything in my location to Win7.  Not so fortunate at a couple of the other plants.  Starting getting calls about a week ago about possible migrations routes.  Ugliest is some equipment using Traditional DAQ.  I tried to warn them a couple of years ago that someone would need to invest some time to make the converision to DAQmx and do some extensive testing.  At least the DAQ cards are compatible with DAQmx!
Message 7 of 36
(16,854 Views)
Most people on this forum are in a different situation then most users of Microsoft OSs.  We know the pain of being forced into updating more then others, but we also are able to hold on to our older OSs even longer.  But one thing I always try to mention is just how long support for XP has lasted.
Someone running XP today is running an OS that was released 12 Years ago.  Windows 95 was released 18 years ago.  So someone running XP today, is running an OS that was as old as Windows 95 was in 2008.  While I'm sure there are systems running Windows 95 today (and older OSs) it is strange to me that support, and even usage of XP has lasted as long as it has.  If you started using computers at 16 when XP was first released, you could be 28 today and have never used another OS for consumer use.
Message 8 of 36
(16,842 Views)
Is there an official support for XP Mode in Windows 7?  Or does this support stop also affect this part of Windows 7?
Edit: Yup, apparently this part of Windows 7 is now officially not supported.
Message 9 of 36
(16,835 Views)
Just wait another 15 years (or so) and we get cool XP emulators like we have for C64, Atatri etc.
including A20 gate sim , hard disk delay emulation,   you name it  🙂
no physical hardware needed... it's all in the cloud ....
Greetings from Germany
Henrik
LV since v3.1
Message 10 of 36
(16,755 Views)
