BreakPoint
Forum name/avatar on NI week badges?
I was planning to wear my hooded black wizard cloak, but I don't think it will fit in my carry-on.
It is also not compatible with the Austin Weather.
(Arguably, it might be compatible with the convention center climate controls, though. :D)
Last year, under cover of my cloak, I actual snuck into the convention center control center and took a picture of the climate control. There are only two settings!
Here it is, but we could have guessed it. 😄 (They are using the same vendor as the Santa Monica Blue Bus lines. 🐵
Message 11 of 15
(4,710 Views)
I'll take a blizzard any day, thanks Smiley Happy
Message 12 of 15
(4,703 Views)
Forum names would be a great idea.  How often would you walk past someone, not knowing that you chat all the time on the forums.\
Message 13 of 15
(4,688 Views)
Wayne. unfortunately I will be sending my presents rather than my prescience or presence to Austin this year.
type that on an android:)
Message 14 of 15
(4,672 Views)
I have red hair, so I'm easy to spot. If I try and reenact my avatar, I will be quite dizzy, and most likely vomitting by the end. Just do not confuse me with Jack Dunaway; although, if you want to confuse my programming style and LabVIEW knowledge with his, you're more than welcome to do so.
Message 15 of 15
(4,629 Views)
