07-20-2012 01:50 PM - edited 07-20-2012 01:51 PM
I was planning to wear my hooded black wizard cloak, but I don't think it will fit in my carry-on.
It is also not compatible with the Austin Weather.
(Arguably, it might be compatible with the convention center climate controls, though. :D)
Last year, under cover of my cloak, I actual snuck into the convention center control center and took a picture of the climate control. There are only two settings!
Here it is, but we could have guessed it. 😄 (They are using the same vendor as the Santa Monica Blue Bus lines. 🐵
07-20-2012 02:09 PM
I'll take a blizzard any day, thanks
07-20-2012 03:05 PM
Forum names would be a great idea. How often would you walk past someone, not knowing that you chat all the time on the forums.\
07-20-2012 04:14 PM
07-23-2012 01:39 PM - edited 07-23-2012 01:40 PM
I have red hair, so I'm easy to spot. If I try and reenact my avatar, I will be quite dizzy, and most likely vomitting by the end. Just do not confuse me with Jack Dunaway; although, if you want to confuse my programming style and LabVIEW knowledge with his, you're more than welcome to do so.
