BreakPoint
Goodby DFGray, Hello ShadesOfGray
As some of you already know, I switched jobs the beginning of January 2015, so my DFGray alias will no longer be active. I am now, once again, an industrial physicist. It is not unreasonable to assume I will continue to use LabVIEW and participate in these forums, although not at my previous level. I look forward to continued interaction with you all.
Thanks to AristosQ for the new alias!
the entity formerly known as DFGray
Message 1 of 9
(10,217 Views)
Why not simply update you NI.Com profile with the new e-mail address (to lose the blue hue) and change the alias?  The forum needs all the TE's it can keep active.
Good luck in your new roll
Message 2 of 9
(10,213 Views)
That was my first thought.  I don't even see a need to change aliases.
NI is losing a great employee.  Good luck in your new position.  Please don't be shy around here.
GCentral
Message 3 of 9
(10,210 Views)
(There might be some policy because old posts written as a blue member might not be fitting for a yellow member. I don't really know...)
Damien, I always enjoyed your posts and hope you will continue to enlighten us. I wish you great success in your new job!
Message 4 of 9
(10,141 Views)
Cool avatar, too.
___________________
Try to take over the world!
Message 5 of 9
(10,101 Views)
Cool avatar, too.
The Avatar probably needs upgrade with a highly promoted 2014 new feature 😮
Message 6 of 9
(10,091 Views)
Thank you for all of your contributions, so far, hope to see you remain a member of our community. I think you changed to this alias to take advantage of the all or the current media attention!
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 7 of 9
(10,070 Views)
There's  always!
ShadesOfGray
but do not use   an under bar!
ShadeOfGray
Message 8 of 9
(10,038 Views)
Is that....  50 of them?
(yeah... somebody did have to write that)
Message 9 of 9
(9,783 Views)
