BreakPoint
Goodby DFGray, Hello ShadesOfGray
As some of you already know, I switched jobs the beginning of January 2015, so my DFGray alias will no longer be active. I am now, once again, an industrial physicist. It is not unreasonable to assume I will continue to use LabVIEW and participate in these forums, although not at my previous level. I look forward to continued interaction with you all.
Thanks to AristosQ for the new alias!
the entity formerly known as DFGray
Message 1 of 9
(10,397 Views)
Why not simply update you NI.Com profile with the new e-mail address (to lose the blue hue) and change the alias?  The forum needs all the TE's it can keep active.
Good luck in your new roll
Message 2 of 9
(10,393 Views)
That was my first thought.  I don't even see a need to change aliases.
NI is losing a great employee.  Good luck in your new position.  Please don't be shy around here.
Message 3 of 9
(10,390 Views)
(There might be some policy because old posts written as a blue member might not be fitting for a yellow member. I don't really know...)
Damien, I always enjoyed your posts and hope you will continue to enlighten us. I wish you great success in your new job!
Message 4 of 9
(10,321 Views)
Cool avatar, too.
___________________
Try to take over the world!
Message 5 of 9
(10,281 Views)
Cool avatar, too.
The Avatar probably needs upgrade with a highly promoted 2014 new feature 😮
Message 6 of 9
(10,271 Views)
Thank you for all of your contributions, so far, hope to see you remain a member of our community. I think you changed to this alias to take advantage of the all or the current media attention!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 7 of 9
(10,250 Views)
There's  always!
ShadesOfGray
but do not use   an under bar!
ShadeOfGray
Message 8 of 9
(10,218 Views)
Is that....  50 of them?
(yeah... somebody did have to write that)
Message 9 of 9
(9,963 Views)
