BreakPoint
Hello Dear LV coders! :)
Hmm, as i see there some bugs 🙂 Some kind of xml tag parsing issue in the Help menu...?
Message 11 of 16
(1,515 Views)
Yeah, there are a few of those in there.  For instance, I recently had a save for previous error due to interfaces.
Message 12 of 16
(1,504 Views)
You actually found an Xnode (Error Ring) in save for previous WTF?  That "File "%s..." has to be an Error Ring.
You need to mention that elsewhere and see if DNatt can duplicate and fix that.
Message 13 of 16
(1,294 Views)
To my knowledge all of the code in the SFP dialogs being displayed in those screenshots is C++ code, I don't think there's any LabVIEW code (XNodes or otherwise) at fault here.
Message 14 of 16
(1,280 Views)
@Blokk wrote:
Thanks, but it seems it does not help. It was already set to Hungary (English), but still have Korean language 🙂 Maybe i should start to learn it, anyway it is a nice language 😄
(i will contact site support)
do you see the same sort of conduct, when you access the ni website using a different browser (e.g. brave) or a fresh install of your current browser?
Message 15 of 16
(1,187 Views)
Hi! I have got it solved, so i did not tested further with other browsers.
See my previous post:
"it seems toggling country to Ireland then back to Hungary (English) helped, now i have full English language in the site
Message 16 of 16
(1,178 Views)
