BreakPoint
I took a new position as a Manufacturing Engineer
It seems he is wiring a boolean to a property node of a latch action switch (first guess, what else could it be?).
This will probably give an error at run time.
Message 11 of 23
(8,747 Views)
I'm fairly used to messy code.  But the part that is annoying me more than anything is one of my main pet peeves: Value property node.  Must...resist...killing...author...
Message 12 of 23
(8,737 Views)
I opened a brandy-new application, yesterday, that we bought from an equipment manufacturer to control a process on my new line.  That author had all of the controls & indicators outside the main While loop and wrote/read everything using Value property nodes - even ones that were only read/written in one place.  The sad thing is that the JKI State Machine was used (at my predecessor's request) and there was the "Data Initialize" state with the cluster that was never referenced again...
Jim
Message 13 of 23
(8,700 Views)
@JÞB wrote:
(Hey thats a depreciated read from text- how old is this code?)
I had to LOL. The code isn't worth as much as it used to be? Well, at least it wasn't deprecated. I can appreciate that.
     Rob
Message 14 of 23
(8,574 Views)
There is soooooooo much wrong with that code, but I have to say that this bit is probably one of my favourite issues I see often:
Where is the wire?????? Oh, probably behind the case structure. How do I get to it to trace it back with a simple triple click then?? Erm....dang.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 15 of 23
(8,493 Views)
I noticed this the other day.  Wanna guess what's in the False case?
2015-01-09 09_49_44-I took a new position as a Manufacturing Engineer - Discussion Forums.png
Jim
Message 16 of 23
(8,481 Views)
A TRUE constant?  Which would mean it could just be replaced with a NOT.
A FALSE constant?  Well, who knows what they are trying to do.
Message 17 of 23
(8,473 Views)
Don't you read my posts Jim?
Message 18 of 23
(8,468 Views)
Well I still do.
Ben
Message 19 of 23
(8,464 Views)
Well I still do.
Ben
Flattering - stay safe!
Message 20 of 23
(8,446 Views)
