BreakPoint
I used a stacked sequence today. So sue me.
Smiley Tongue
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
Message 1 of 18
(9,479 Views)
Just curious, why not wrap the two functions into one (such as "init" or "setup" or whatever). Then have an array of clusters, one cluster  array element per channel, then have said function called in a for loop.
Message 2 of 18
(9,469 Views)
And don't forget to propagate the error cluster between cases with the shift register.
GCentral
Message 3 of 18
(9,461 Views)
SUBPOENA DUCES TECUM
TO:      PaulG
            forums.ni.com
            Breakpoint Forum
You are hereby commanded to produce for inspection and/or copying on or before April 15, 2013 at noon at the offices/home of NI's Breakpoint Forum, any and all documents, records, or other tangible things which are in your possession or under your control relating to
__________The heinous crime of using a Stacked Sequence structure in production code.___________________
Fail not under penalty of law.
Jim
Message 4 of 18
(9,453 Views)
Bite me, bite me and bite me. Smiley Tongue
PaulG.
Message 5 of 18
(9,423 Views)
Consider it done
Gosh, do you have to pay for your horizontal pixels or whats the deal?
Message 6 of 18
(9,418 Views)
I think PaulG was framed, you be the judge.
Hopefully order is maintained in the court.
-AK2DM
Message 7 of 18
(9,417 Views)
For his crime, he is pretty much guaranteed an order of execution at his sentencing.
-AK2DM
Message 8 of 18
(9,414 Views)
There is absolutely nothing wrong with stacked sequences. In fact I use them in a central part of my most advanced code where they provide the cleanest solution.
(two frames, each frame needs the same inputs, only the last frame outputs something, no sequence locals)
However, if abused, they an easily lead to the most unreadable am unmaintainable code, especially if sequence locals are involved and there are many frames.
Message 9 of 18
(9,390 Views)
Yes there is. As soon as you need to pass data between frames you're dealing with sequence locals, which are just the worst.
Message 10 of 18
(9,379 Views)
