BreakPoint
Incongruous sightings of LabVIEW/NI
@Gregory wrote:
Sorry to add to the pedantry, but tst said "vertically centered". It takes some creativity to get a numeric indicator vertically centered on a much taller background. It could be done with the transparent indicator on top of a decoration.
Non-appoligetically adding to the pedantary
Easier to just show a rectangular LED indicator or, colorbox and justify the Caption vertically and horizontally centered.  Still, that is some work.  And a bit of creativity.   So, likely something else was used.  (Although,  I have used it!)
Message 121 of 197
(3,753 Views)
OK.. not friday yet, but holidays are near...
Just another way to have -vertical- alignment... technically...
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
Message 122 of 197
(3,736 Views)
From some random Facebook video about wind-tunnel testing:
I am always surprised when professional (?) production software still shows the icon and toolbar. 😄
Message 123 of 197
(3,696 Views)
That even has an Abort Button!
Worse, I think I see that the run arrow looks funky and the Run Continuous glyph looks bold
Message 124 of 197
(3,691 Views)
The CATRA Automatic Edge Tester uses a LabVIEW application to control the motors and drives as well as do the data acquisition and processing to evaluate the sharpness and durability of knife edges:
https://www.youtube.com/watch?v=FOIGaETxEh8
I ran across this because I worked for several years on a fully automated robotic knife sharpening system, which uses a LabVIEW front-end (but it's very tastefully done, you can't tell at a glance it's built in LabVIEW) and multiple cRIOs to accomplish real-time control over the robots to enable them to do force-feedback guided grinding and sharpening of the knives.
https://www.youtube.com/watch?v=Bk2yP5cgcws
Jorr-El
Systems Engineer
Testeract: Automated Test Specialists
Message 125 of 197
(3,601 Views)
Stunning UI design.. just a pity that they didn't do the icon...
Message 126 of 197
(3,656 Views)
Here another appearance. Seifert DP602 fully automated x-ray testing machine in action starting from 3:08 (LabVIEW starring at 3:55):
It is LabVIEW 7.1 + VDM. Something from 2005.
And sorry, I didn't change standard default icon. 😉
Message 127 of 197
(3,594 Views)
And one more here:
You can easily recognize the "standard" LabVIEW indicators at 1:25:
It is LabVIEW 2010 (I guess). And yes, the standard LabVIEW icon was changed this time 😉
Message 128 of 197
(3,590 Views)
@Andrey_Dmitriev wrote:
And one more here:
And one more here:
I am not surprised at all!  There is a LabVIEW Champion writing code for Phoenix.
Message 129 of 197
(3,557 Views)
How Two Physicists Unlocked the Secrets of Two Dimensions
LabVIEW in the Taskbar @ 1:34
Patrick Allen: FunctionalityUnlimited.ca
Message 130 of 197
(3,360 Views)
