BreakPoint
Indians thread
It happens. Now stop banging your head to that digital wall. Your digital face is digitally red.
Vaibhav
Message 1061 of 1,232
(9,933 Views)
@manumohannair wrote:
I had one more condition in that debut-ant century list ;). He should hit debut century when sharing the crease with Sachin.
I think the moment two batsmen share the same crease with one another, one of them gets run-out most probably (if not helped by great mis-fielding).
Vaibhav
Message 1062 of 1,232
(9,933 Views)
Lemme clean the expression "Crease" with "Creases in the same Pitch". This should run without "Run-Time Errors" ;).
Message 1063 of 1,232
(9,928 Views)
LOL 😄 "Creases on the same Pitch" won't give any "Run-time Error" as the batsmen are given more freedom to "run."
Ok, you cleared the logical error, so there won't be any "Execution Time Error," however, the expression has a bit of ambiguity (sharing two creases, when each of them is on the opposite sides, is not sharing :P) so there might be data memory leak problem and it can crash the system any time. In short, the repair work does not guarantee stability to your program. To make it robust, you need to rewrite the whole expression and just put "sharing the same pitch" (which is far from "sharing the same wicket" - technically more correct), but close to your desired expression.
Vaibhav
Message 1064 of 1,232
(9,911 Views)
Just make sure to protect against race conditions.
Message 1065 of 1,232
(9,900 Views)
@Vaibhav wrote:
Muks,
(who is S Amarnath??
Hi Vaibhav,
Pl read this article http://cricket.rediff.com/report/2010/jul/29/life-comes-full-circle-for-suresh-raina.htm
It seems he is Surinder Amarnath.
- Partha ( CLD until Oct 2027 🙂 )
Message 1066 of 1,232
(9,899 Views)
And the test ends in a draw!!
As expected. I feel this is the most boring series in recent times.Smiley Tongue
Message 1067 of 1,232
(9,873 Views)
Seems like the test is evenly poised for both the teams with a definite result. India's chances depends on Viru,Dravid ,Laxman and Sachin's experiance to handle such a track.
Message 1068 of 1,232
(9,787 Views)
And what a win india have managed. Great batting by vvs. Sad I was not able to catch that live. Anyway seems like a really good test won and series levelled.
Message 1069 of 1,232
(9,748 Views)
Glad I didnt see the last match. The score board looks pathetic.Smiley Sad
Message 1070 of 1,232
(9,723 Views)
