BreakPoint
Metrication errors in the kitchen
@altenbach wrote:
Turmeric has significantly more flavor. Annatto is different. You should try it in your potato salad. 😄
(Quote "It is often used to impart a yellow to red-orange color to foods, but sometimes also for its flavor"
Color is important and plays a crucial role in food presentation! Sometimes I even use butterfly pea flower tea when cooking rice. 😄
More questionable is treating meat with carbon monoxide to retain the fake bright red color, giving a fresher appearance.
Awesome,   but seriously WHAT required the 4.1 boolean change?  I honestly never understood and, would like to learn.
It is a serious question.  I never found any document that answered that.  I hoped that your experience would help. 4.1 and 7.1 ?
Message 11 of 13
(596 Views)
I found a distillery in NC that adds butterfly pea flower to their gin.  I add lemon juice and honey simple syrup...
Jim
Message 12 of 13
(576 Views)
Not sure why this is here. I assume you wanted it here.
Anyway, the LV help for Type Cast has this to say:
LabVIEW 4.x and earlier stores Boolean data in two bytes unless the data is in an array, in which case LabVIEW stores each Boolean element in a single bit. LabVIEW 5.0 and later stores Boolean values in a single byte, regardless of whether it is in an array
LV 8.0 had a change to the type descriptors format, so things that deal with that (like Flatten to String) would have the option for dealing with 7.x data.
___________________
Try to take over the world!
Message 13 of 13
(562 Views)
