BreakPoint
Monthly Bugs, October 2015
Continued from the September 2015 bug thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 10
(10,353 Views)
 Both controls have coercion and minimum increment size set.
1. Set value on control SetVal to a value using the up / down tabs on control
2. type the same value on Test control
3. run VI,  the greater or equal? function does not return a true, even though them should be equal
Message 2 of 10
(10,314 Views)
Please post in the LabVIEW forum. The bug thread is not for discussions of bugs.
(Just show enough digits!)
... and yes, you would think if it coerces to the closest multiple of 0.05, both values should be the same. Somebody would need to look at the underlying code to see what's going on.
Message 3 of 10
(10,309 Views)
Icons with non-default bounds don't upgrade correctly to LabVIEW 2015.
Detailed discussion is here.
No CAR yet...
Message 4 of 10
(10,231 Views)
CAR 550019
Thread with CAR assigned
Related thread with VI demonstrating the bug
The TDMS List Contents in 2015 was updated to generate an error when it is requested to list the contents of a group that doesn't exist.  It may also return the list of channels from a group that does exist, from a previous call to this function.
Message 5 of 10
(10,178 Views)
CAR 550071 (no confirmation from NI)
Duplicate icon behavior on taskbars that appear on multiple monitors, in Windows 10.
Message 6 of 10
(10,168 Views)
No CAR yet...
CAR #515054 reopened
Looked it up and that is the correct CAR number for the issue.
Message 7 of 10
(10,116 Views)
Display format settings not maintained when changing to array.
CAR#552697
Message 8 of 10
(10,048 Views)
A certain sequence of actions while editing a state in the statechart module can cause a LabVIEW crash
http://forums.ni.com/t5/LabVIEW/LV2014SP1-Statechart-Module-editor-bug-causing-hard-crash-with/td-p/...
Message 9 of 10
(9,973 Views)
Message 10 of 10
(9,900 Views)
