10-01-2015 01:26 AM
Continued from the September 2015 bug thread
The posting rules are as always:
10-02-2015 02:09 PM
Both controls have coercion and minimum increment size set.
1. Set value on control SetVal to a value using the up / down tabs on control
2. type the same value on Test control
3. run VI, the greater or equal? function does not return a true, even though them should be equal
10-02-2015 02:15 PM - edited 10-03-2015 09:47 PM
Please post in the LabVIEW forum. The bug thread is not for discussions of bugs.
(Just show enough digits!)
... and yes, you would think if it coerces to the closest multiple of 0.05, both values should be the same. Somebody would need to look at the underlying code to see what's going on.
10-06-2015 02:05 PM
Icons with non-default bounds don't upgrade correctly to LabVIEW 2015.
No CAR yet...
10-09-2015 08:29 AM
CAR 550019
Related thread with VI demonstrating the bug
The TDMS List Contents in 2015 was updated to generate an error when it is requested to list the contents of a group that doesn't exist. It may also return the list of channels from a group that does exist, from a previous call to this function.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
10-09-2015 10:05 AM
CAR 550071 (no confirmation from NI)
Duplicate icon behavior on taskbars that appear on multiple monitors, in Windows 10.
10-13-2015 11:50 AM
No CAR yet...
CAR #515054 reopened
Looked it up and that is the correct CAR number for the issue.
10-22-2015 06:25 PM
10-28-2015 04:13 PM
A certain sequence of actions while editing a state in the statechart module can cause a LabVIEW crash
11-01-2015 03:22 AM
